Andyon98
I have a "Do you want to quit button" with ""Yes" and "No" buttons. How do I close the window along with the main menu from which I press cancel from?
I was wondering how would I close all windows from pressing on the yes button, im sure its simple... im just not sure on how to write it the most efficient way.
Re: I have a "Do you want to quit button" with ""Yes" and "No" buttons. How do I close the window along with the main menu from which I press cancel from?
Not exactly sure what you are after, but maybe something like this?
nw1_expr = Expr(
	New Window("1",
		Text Box("Window1"),
		H List Box(
			Button Box("OK"),
			Button Box("Cancel", << Set Function(function({this},
				(this << top parent) << Close Window;
				nw2_expr;
nw2_expr = Expr(
	New Window("2",
		Text Box("Window2"),
		H List Box(
			Button Box("OK"),
			Button Box("No", << Set Function(function({this},
				nw1_expr;
nw1_expr;
Here is a bit of JSL that seems to close all of the windows and then closes JMP.  There may be easier ways.
cw = Current Window() << get window title;
For( i = 99, i >= 1, i--,
	If( Window( i ) << get window title != cw & Window( i ) << get window title != "",
		Window( i ) << close window
Main Menu( "exit jmp" );
Andyon98
Say I don’t want to close jmp and I only want to close one window at a time; e.g.
You press cancel on the first window and another window pops up, at this point you want the first window to close as the second window has opened.
Then if you press on the “No” button box of the second menu, the second menu should close and the first menu should open again or you should be presented with the first menu again.
nw1_expr = Expr(
	New Window("1",
		H List Box(
			Button Box("OK"),
				nw2_expr;
nw2_expr = Expr(
	New Window("2",
		H List Box(
			Button Box("OK"),
				nw1_expr;
nw1_expr;
Andyon98
That's exactly what I was looking for, thank you!
