NetflixCrow956
word missing
dt<< New Column( "op status", Character, "Nominal", Set Selected );
If( Is Missing( Column( dt, "Status Operation" )[x],Word( 1, "PCNF" ) | Word( 1, "CNF" ) ), Column(dt, "op status") == "Q" );
Hello everyone, I would like to create a new column and in this column, if the words PCNF or CNF do not appear in the column :Status Operation, on this line, put "Q" in the Column :op status but I do not know the syntax. I thank you for your help.
pmroz
Re: word missing
Here's a column formula that will work:
dt << New Column( "op status", Character, "Nominal",
		Formula(
			If(
				!Contains( :Status Operation, "PCNF" ) &
				!Contains( :Status Operation, "CNF" ),
				"Q"
Re: word missing
Using a formula (or << Set Each Value) is easiest option. What type of formula to use depends on what sort of values your Status Operation has. Could you provide couple of example values from that column?
pmroz
Re: word missing
		Formula(
			If(
				"Q"
Re: word missing
Try this
	Character,
	"Nominal",
	Set Selected,
	formula(
		If(
			Is Missing( :Status Operation ) | (Contains( :Status Operation, "PCNF" ) == 0 &
			Contains( :Status Operation, "CNF" ) == 0),
			"Q",
			:Status Operation
