How to write .jmp files with JMP python
Hi,   I am using JMP19.1.1
I see examples of how to use JMP or JSL to open files, add jsl scripts for plotting and then run them.
Are there examples to use JMP Python to open csv files and write .jmp files with charts in them?   What do people do?
Adrian
Re: How to write .jmp files with JMP python
Saving can be done with save method of DataTable
To add table scripts you can use either run_jsl or scripts with jmp.Expression
Thanks for responding.  I am talking about not using the jmp libraries.   I am talking about using python code that is processing data, that spits out csv files.   I want to switch to writing .jmp files.   Is there a way to do this?   i.e.  Pandas dataframe directly to .jmp ?
Thanks
To my knowledge no. You would need to run the Python inside JMP.
Here is what I try to run:
from pathlib import Path
import jmp
csv_path = Path(r"C:\Work\debug\jmp_debug\CT_Pro_PRO0CV2_pass_fail_05302026.csv")
out_path = Path(r"C:\Work\debug\jmp_debug\CT_Pro_PRO0CV2_pass_fail_05302026.jmp")
print("Opening:", csv_path)
dt = jmp.open(str(csv_path))
print("Saving:", out_path)
dt.save(str(out_path))
print("Done")
I run it this way:  & "C:\Program Files\JMP\JMP\19\jmp.exe" -R "C:\Work\debug\jmp_debug\jmp_csv_to_jmp_simple.py" in powershell.   The problem is this pops up three windows.        Do you know if there is anyway to run JMP in a headless fashion?    I.e.  Run it and not have a collage of windows pop open ?
The main reason to go directly to .jmp is these files are 4-10 GB in csv format.  So this is painful.   Ideally, we could pass a pandas dataframe to the jmp table and write it
This is really painful.  It appears there is no real way to make this run in a headless fashion.  This is really surprising.   I must me wrong and not have the right documenation.  If someone has information on how to run jmp in a headless fashion, this would be really helpful.  I.e.  I can run this in a script and not get three to four new windows popping open.
In JMP 19.1.3, and plain vanilla Python 3.13.3 (Non JMP), I got the following improvement.  This only pops up the .jmp table being created.  So this is close to a solution.   I would really still like to know if there is headless information ?
import time
import win32com.client
def jsl_quote(path_or_text) -> str:
text = str(path_or_text)
text = text.replace("\\", "\\\\").replace('"', '\\"')
return f'"{text}"'
csv_path = Path(r"C:\Work\debug\jmp_debug\05302026.csv")
out_path = Path(r"C:\Work\debug\jmp_debug\05302026.jmp")
jmp = win32com.client.Dispatch("JMP.Application")
# Try False first. If nothing works, set True while debugging.
jmp.Visible = False
jsl = f"""
dt = Open({jsl_quote(csv_path)},Invisible);
dt << Save As( {jsl_quote(out_path)} );
Close( dt, No Save );
print("Running JSL...")
jmp.RunCommand(jsl)
# Give JMP a moment if RunCommand returns before save completes.
time.sleep(2)
print("Saved?", out_path.exists(), out_path)
