lala
Level IX
How to write Python or JSL to automatically log in to an email account to send and receive emails?
Thanks Experts!
Directly read the current JMP table:
Row 1 contains the sender email information
Row 2 contains the receiver email information
After receiving the email, directly write the received content into row 2 of the “Content” column in the current table.
dt = New Table(
    "EmailConfig",
    Add Rows(2),
    New Column("Email", Character, Set Values({
        "A@gmail.com",
        "B@gmail.com"
    New Column("Password", Character, Set Values({
        "AA",
        "BB"
    New Column("Content", Character, Set Values({
        "Test",
Re: How to write Python or JSL to automatically log in to an email account to send and receive emails?
For Python, this isn't correct place to ask.
For JSL, what type of service do you have? Do you have access to some API to send and receive the emails which JMP can access?
lala
Level IX
Thanks Experts!
AI's
it's not work.
sender = Char(dt:Email[1]);
pwd_sender = Char(dt:Password[1]);
content = Char(dt:Content[1]);
receiver = Char(dt:Email[2]);
pwd_receiver = Char(dt:Password[2]);
proxy = "--proxy \!"http://127.0.0.1:7897\!"";
message_file = "C:\temp\jmp_message.txt";
Save Text File(message_file, "Subject: Test Email\n\n" || content);
send_options = {"smtp://smtp.gmail.com:587", "--mail-from", sender, "--mail-rcpt", receiver, "--user", sender || ":" || pwd_sender, "-T", message_file, "--ssl-reqd", proxy};
rp_send = Run Program(
	Executable("curl.exe"),
	Options(send_options),
	ReadFunction(Function({this}, send_out = this << Read; Show(send_out); ))
Wait(10);
search_options = {"--url", "imaps://imap.gmail.com/INBOX", "--user", receiver || ":" || pwd_receiver, "-X", "\!"SEARCH ALL\!"", proxy};
rp_search = Run Program(
	Options(search_options),
	ReadFunction(Function({this}, search_out = this << Read; ))
match_pos = Contains(search_out, "* SEARCH");
if(match_pos > 0,
	ids_start = match_pos + Length("* SEARCH ");
	ids_end = Contains(search_out, "\r\n", ids_start);
	ids = Substr(search_out, ids_start, ids_end - ids_start);
	ids = "";
id_list = Words(ids, " ");
if(N Items(id_list) > 0,
	last_id = id_list[N Items(id_list)];
	last_id = "";
	dt:Content[2] = "Receive Failed";
	throw();
fetch_options = {"--url", "imaps://imap.gmail.com/INBOX", "--user", receiver || ":" || pwd_receiver, "-X", "\!"FETCH " || last_id || " BODY.PEEK[TEXT]\!"", proxy};
rp_fetch = Run Program(
	Options(fetch_options),
	ReadFunction(Function({this}, fetch_out = this << Read; ))
body_start = Contains(fetch_out, "{");
body_end = Contains(fetch_out, ")", body_start);
body_length = Num(Substr(fetch_out, body_start + 1, body_end - body_start - 1));
content_start = body_end + 2;
received_content = Substr(fetch_out, content_start, body_length);
cleaned = Trim(Regex(received_content, "[\\r\\n]+", " ", "GLOBALREPLACE"));
dt:Content[2] = cleaned;
I cannot directly help you, but you can use VScript to send mail with JMP, use Mail() command, powershell with Send-MailMessage or other options.
