Welcome to the community.
Your data is easily entered into JMP, with the Excel Wizard, to guide you through.
Typically the analytical format of the data is laid out vertically, not horizontally. Therefore stacking all of your year data is how I would typically start.
I have provided a couple of scripts that I put together that read in the 2 spreadsheets you provided. In both cases, I input and transformed the data using interactive JMP, and then took from JMP, the scripts it produced to do the actual work, and saved them into the scripts below.
For the Verkehrsunfalle data
![txnelson_0-1679806783704.png txnelson_0-1679806783704.png](https://community.jmp.com/t5/image/serverpage/image-id/51479i0144BAC7CAAD36CC/image-dimensions/792x281?v=v2)
![txnelson_0-1679806895279.png txnelson_0-1679806895279.png](https://community.jmp.com/t5/image/serverpage/image-id/51480i9416CD0AE29E3DA6/image-dimensions/437x480?v=v2)
dt = Open(
"path to your data",
Worksheets( "46241-0022" ),
Use for all sheets( 1 ),
Concatenate Worksheets( 0 ),
Worksheet Settings(
1,
Has Column Headers( 1 ),
Headers Start on Row( 4 ),
Data Starts on Row( 5 ),
Data Starts on Column( 1 ),
Data Ends on Row( 0 ),
Data Ends on Column( 0 ),
Replicated Spanned Rows( 1 ),
Suppress Hidden Rows( 1 ),
Suppress Hidden Columns( 1 ),
Suppress Empty Columns( 1 ),
Treat as Hierarchy( 0 ),
Multiple Series Stack( 0 ),
Import Cell Colors( 0 ),
Limit Column Detect( 0 ),
// Fill in rows where repeating values have been deleted
For( i = 1, i <= 2, i++,
For( k = 1, k <= N Rows( dt ), k++,
If( Column( i )[k] != "",
hold = Column( i )[k]
Column( i )[k] = hold;
// Get rid of dashes being used as an indicator of blank data
// Also, change columns to numeric after the dashes are changed
for(i=4,i<=ncols(dt),i++,
try(as column(i)[dt<<get rows where(as column(i)=="-")] = "");
column(i)<<data type(numeric)<<modeling type(continuous);
// Stack all of the Years data
dtStack = dt << Stack(
columns( :"1995"n, :"1996"n, :"1997"n, :"1998"n, :"1999"n, :"2000"n, :"2001"n ),
Source Label Column( "Jahr" ),
Stacked Data Column( "Straßenverkehrsunfälle" ),
"Non-stacked columns"n(
Keep(
:BundesländerStraßenklasseOrtslage, :BundesländerStraßenklasseOrtslage 2,
:BundesländerStraßenklasseOrtslage 3
Output Table( "Final" )
// Change the Jahr column to numeric, ordinal
dtStack:Jahr << data type(numeric)<<modeling type(ordinal);
// Change column names to meaningful names
column(dtStack, 1) << set name("Bundeslander");
column(dtStack, 2) << set name("Straßenklasse");
column(dtStack, 3) << set name("Ortslage");
// Entfernen Sie die Kategorie "Insgesamt"
dtStack << select where( :Ortslage == "Insgesamt" );
dtStack << delete rows;
dtStack << select where( :Straßenklasse == "Insgesamt" );
For the Eurostat data
Again entered into JMP using the Excel Wizard, and then stacking the data
![txnelson_1-1679807087962.png txnelson_1-1679807087962.png](https://community.jmp.com/t5/image/serverpage/image-id/51481iF4933E11E834A7E0/image-dimensions/847x305?v=v2)
![txnelson_0-1679807199387.png txnelson_0-1679807199387.png](https://community.jmp.com/t5/image/serverpage/image-id/51482iDE3A6F5EBC726695/image-dimensions/491x709?v=v2)
names default to here(1);
dt = // Import Excel file: lebTHI_EurostatTable.xls
// → Data Table( "Sheet0" )
Open(
Worksheets( "Sheet0" ),
Worksheet Settings(
1,
Headers Start on Row( 3 ),
Data Starts on Row( 4 ),
// delete rows where footnotes were input
dt << select where(:"1997"n =="");
dt << delete rows;
// Stack all of the year data
columns(
:"1990"n, :"1991"n, :"1992"n, :"1993"n, :"1994"n, :"1995"n, :"1996"n,
:"1997"n, :"1998"n, :"1999"n, :"2000"n, :"2001"n, :"2002"n, :"2003"n,
:"2004"n, :"2005"n, :"2006"n, :"2007"n, :"2008"n, :"2009"n, :"2010"n,
:"2011"n, :"2012"n, :"2013"n, :"2014"n, :"2015"n
Stacked Data Column( "Arbeitslosenquote" ),
"Non-stacked columns"n( Keep( :geo\time ) ),
Output Table( "Stacked Unemployment " )
// Change : to blanks
dtStack:Arbeitslosenquote[dtStack << get rows where(:Arbeitslosenquote == ":")] = "";
// Change Arbeitslosenquote to numeric, continuous
dtStack:Arbeitslosenquote << datatype(numeric)<<modelingtype(continuous);
// Convert to JMP percent value and change display format
for each row( :Arbeitslosenquote = :Arbeitslosenquote/100);
dtStack:Arbeitslosenquote<<format("Percent", 7,2);
// Change Jahr to numeric, ordinal
dtStack:Jahr << datatype(numeric)<<modelingtype(ordinal);
