In evaluation of glue ?
I was just writing a simple code but I ran into preview text error: Unable to open file, in access evaluation of "Glue"
Can anyone advise me on the thing I didn't do correctly?
dt = Open (); //open a csv or excel file from any folder
Sa = Current data table ();
Re: In evaluation of glue ?
I suspect you have objects in your JMP memory area that have not been cleared.  I have 2 suggestionsw.
  1. Close and restart your JMP session
  2. Isolate the memory for your JSL by adding Names Default to Here(1); to your JSL.  That will insure that your JSL will be in it''s own memory NameSpace
    dt = Open(); //open a csv or excel file from any folder
    Sa = Current Data Table();
I tried the second suggestion, but the problem still persisted. I'll check on the 1st one then.
Alright, I tried the first option and it worked fine ! Thanks again @txnelson
