The task: in addition to the shapes of the countries, add a compass to quickly select the countries of the respective region. With the shapes functionality it should be easy to generate the shapes for the compass - but I don't know how to use 2 different columns as shapes ...
Created:
Apr 7, 2024 02:47 AM
| Last Modified: Apr 8, 2024 2:01 PM(2951 views)
| Posted in reply to message from hogi 04-07-2024
edit:
workaroud: for shapes one can apply the same trick as for the Heatmap graph: add another point plot to generate the additional controls outside of the wafer map
Created:
edit:
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '745023' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '745023') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '745023') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
