How to use Set Property() to make a custerm order for a column?
Hi, Dears,
I have a Demo.jmp which includes 3 columns:
Column Name, Data Type
T, Character
Value,Numeric
SN,Characer
I'd like to make a custerm order on column "T" as "LT","RT","HT" ascending with the script below:
//dt = Open("Demo.jmp");
//please open Demo.jmp manually
dt << Recode Column( :T, Update Properties( 1 ), Target Column( :T ));
:T <<Set Property( "Value Order",{"LT", "RT", "HT"});
Here is the error info, and I need your suggestion, thanks.
Name Unresolved: Update Properties in access or evaluation of 'Update Properties' , Update Properties( 1 ) /*###*/
Re: How to use Set Property() to make a custerm order for a column?
Do it interactively in JMP and get the script from enhanced log OR  by using Copy Column Properties
Data Table("Demo"):T << Set Property(
	"Value Order",
	{Custom Order({"LT", "RT", "HT"}), Common Order(0), Numerical Order(0),
	Use Locale Comparisons for Characters(0)}
Copy Column / Copy Column properties scripts usually require a bit modification (this is from Copy Column Properties)
Add Column Properties(
	Set Property(
		"Value Order",
	"Value Order",
	Set Property(
		"Value Order",
