Ekarshalev
How to use N missing values in a distribution frequencies table
Hello All,
I have a large table where I have empty cells in some places. I am doing a count using the distribution -> frequencies table. However, the probability is based only on the cells with a value inside. The frequencies table still prints out how many values are missing ("N missing"). I was hoping to be able to put that value in the combined table I make from the frequencies table.
Any help is appreciated.
Here is an example of what I am talking about
dale_lehman
Re: How to use N missing values in a distribution frequencies table
Why not just recode that column so that missing becomes "missing" and then that will appear in the graph as a category?
Ekarshalev
Thx dale,
I have not played with recoding much but it seems like a pretty fast solution.
You can easily do this using Transformation variables.
In the dialog box for the Distribution, simply right click and create a virtual transformational variable;  If you specify the formula as in the example, you can use that new virtual variable for the distribution.
To do this is JSL, here is an example
Distribution(
	Transform Column(
		"sex expanded",
		Nominal,
		Set Property( "Value Order", {Numerical Order( 0 )} ),
		Formula( If( :sex == "", "Missing", :sex ) )
	Nominal Distribution( Column( :sex expanded ) )
Ekarshalev
Thanks txnelson,
This seems like a pretty easy way to do it.
Aside from recoding as mentioned by others, it might be worth while to add to the JMP Wish List a request for an option to display missing values as a category/level in distributions and other places where categorical data is used.
Chris Kirchberg, M.S.2
www.jmp.com
Ekarshalev
Thanks Chris,
I will be sure to do that
