Denver
How to add "Mark Review Status" in an Add-in Script in JMP Clinical
Dear JMP User Community,
We are currently exploring a way to use Add-in scripts to speed up analysis in large clinical trials. However we are unable to see the new data since last reviewed. This requires us to save the Output of the add-in every month and save it in EXCEL, use formulae & flag new values.
Is there a way to enable "Mark Review status" which is a normal functionality in JMP Clinical?
Version of JMP Clinical- Version 7.1.2
Best Regards
Denver
Re: How to add "Mark Review Status" in an Add-in Script in JMP Clinical
Hi @Denver ,
Could you describe the purpose of the add-in in a little more detail?  Are you referring to the  "Review Status" option found in Patient Profiles that changes a reviewed flag from "unreviewed" to "reviewed" or are you looking at the variable that JMP Clinical makes called xxReviewFlag where the possible values are "New", "Modified", "Stable", "Deleted", etc.
Thanks for the clarification.
Chris Kirchberg, M.S.2
www.jmp.com
