How to use JSL to select many consecutive rows in a table?
The table is already in the second column of the selection, how to use JSL to cancel all the selection, and then select the number of rows specified by the number of consecutive rows, select all the columns.
Take dt = Open( "$SAMPLE_DATA/Big Class.jmp" ) for example.
The expression for a row of consecutive choices was not found in the help.
