lwx228
Level VIII
How to use JSL to select many consecutive rows in a table?
The table is already in the second column of the selection, how to use JSL to cancel all the selection, and then select the number of rows specified by the number of consecutive rows, select all the columns.
Take dt = Open( "$SAMPLE_DATA/Big Class.jmp" ) for example.
The expression for a row of consecutive choices was not found in the help.
ian_jmp
Level X
Re: How to use JSL to select many consecutive rows in a table?
Try:
dt << select Rows(6::13);
'Help > Books > Scripting Guide' coupled with 'Help > Scripting Index' are good resources.
uday_guntupalli
Level VIII
@lwx228 ,
Try this ?
// Clear Row Selection
dt << Select Randomly(0.1);
dt << Clear Select();
// Clear Column Selection
dt << Select columns({:age,:sex});
dt << Clear Column Selection();
Best
Uday
lwx228
Level VIII
dt << Go To( Column( 2 ) );
Wait( 0 );
dt << Set Selected Rows( dt[6 :: 13] );
Wait( 0 );
 This JSL cannot be implemented
ian_jmp
Level X
Try:
lwx228
Level VIII
thank ian_jmp!
After selecting rows, how does JSL implement deselect all selections?Make table without any cell selection, thank!
lwx228
Level VIII
"dt << Clear Select()" Sometimes it doesn't work.
uday_guntupalli
Level VIII
@lwx228 ,
Try this ?
Best
Uday
