lala
Level IX
How to use JSL to replace characters with special symbols in ""?
[{"ReqId":"200904","PoolId":"2001"}]
How to
[{\!"ReqId\!":\!"200904\!",\!"PoolId\!":\!"2001\!"}]
lala
Level IX
回复: How to use JSL to replace characters with special symbols in ""?
txt=Get Clipboard();
tx=Substitute(txt,"\!"","/\!\!"");//??
Re: How to use JSL to replace characters with special symbols in ""?
I'm not sure what you want to replace and with what (which is start and which is end?). When you are printing strings which contain quotes, usually using Write() is a good idea so you don't see the JMP's escaped quotes
str = "\[test: "text"]\";
Show(str); // str = "test: \!"text\!"";
Write("\!N");
Write(str); // test: "text"
lala
Level IX
I see
copy this
can see
lala
Level IX
tx=Substitute(txt,"\!"","\!\!\!"");
lala
Level IX
  • Where can I see this syntax?
  • Thanks!
Try something like
// [{\!"ReqId\!":\!"200904\!",\!"PoolId\!":\!"2001\!"}]
txt = Get Clipboard();
// Write(txt);
tx = Substitute(txt,"\!"","\!\!\!"");
// write(tx);
txt2 = "\!"ReqId\!"";
// Write(txt2);
tx2 = Substitute(txt, "\!\!", "");
// Write(tx2);
tx3 = Substitute(Get Clipboard(), "\!\!", "");
// Write(tx3);
Reading about JMP's escape sequences can also be helpful Scripting Guide > JSL Building Blocks > JSL Syntax Rules
