lala
Level IX
How to use JSL to open JSON-formatted files with json default window, only enter the intermediate state?
open C:\2.json with JSON default window, only enter this state
Re: How to use JSL to open JSON-formatted files with json default window, only enter the intermediate state?
Did you select node that you want by selecting the Row checkboxes?
Guillaume
lala
Level IX
I don't need to select a line, just automatically enter the screen
Thank you for your help!
Oh yes, sorry.
You can maybe try this:
Open(
           "/c:/2.json",
           JSON Wizard( 1 )
Guillaume
lala
Level IX
Thanks! But that's not what I want.
The following code that I get from this interface is the correct data.
dt=Open(chartoblob( "C:\2.json" ),JSON Settings(Stack(0),Col("/root/List",Column Name("List"),Fill("Use Once"),Type("Pandas Values"),Format({"Best"}),Modeling Type("Continuous"))),JSON Wizard(0));
