hogi
Level XIII
Properties menu
Via Edit/Properties a user can open the Properties menu on the right of the window.
This menu allows to fine-adjust reports.
Is there further documentation about the Properties Menu?
E.g. the tree structure on the top, what does it represent?
Is there a search function like the xpath functionality for the Display Tree?
Ressel
Re: Properties menu
Probably you know this already, but my response was triggered by "tree structure". Besides properties, it is also possible to view the tree structure of a report by right-clicking into the topmost disclosure icon (the grey triangle lying on one of its catheti) > selecting Edit -> Show Tree Structure.
Per "Jump into JMP Scripting"; which summarizes all I know about the tree structure; this is for finding the different display boxes in a report so these can be adequately referenced.
From the book:
JMP draws a diagram showing the hierarchical organization of the different display boxes that make up the report. ... These are basic display boxes found in most reports, and there is a number associated with each one. Knowing the type and number of the display box enables you to reference individual display boxes in a JMP report.
hogi
Level XIII
Re: Properties menu
Yes, thanks.
The tree structure in the properties menu seems to be similar to the Display Tree - perhaps even the same at a certain depth.
But not exactly the same. Here I marked some entries in the Properties Tree which don't show up in the Display Tree on the left:
Names Default to Here(1);
NewWindow("test", Outline Box("main menu",Distribution(
	Continuous Distribution(
		Column( :height )
	By( :sex )
