UserID16644
How to subtract values from previous row values?
Hi all
Can someone help me how to formulate a formula that would subtract Column 2 to the previous value in Column 1? It should look like this. The column Equation only shows how the subtraction of values should be.TIA
David_Burnham
Re: How to subtract values from previous row values?
Then you need some conditional logic.  Something like:
If( :Column 2 != Lag( :Column 2, 1 ) | Row() == 1,
	:Column 1,
	:Column 2 - Lag( :Column 1, 1 )
-Dave
David_Burnham
You can use the LAG function:
:Column 1 - Lag( :Column 2, 1 )
-Dave
UserID16644
Hi, how about if I wanted to retain the row value before the values in Column 2 changes? Like this one
David_Burnham
	:Column 1,
-Dave
UserID16644
Hi, I have a follow up question tho. What if I needed to add the values from Column 1 to be subtracted in Column 2?
For example,
Column 1Column 2Result
102010
2208
5203
3200
2155
11513
31512
4155
mmarchandTSI
Could you double-check your numbers here?  I'm not sure what's going on when :Column 2 == 15.
But I think this is what you want (based on David's script):
If(
	:Column 2 != Lag( :Column 2 ) | Row() == 1, :Column 1,
	Row() == 2 | Lag( :Column 2, 2 ) != :Column 2, :Column 2 - (:Column 1 + Lag( :Column 1 )),
	Lag( :Result ) - :Column 1
UserID16644
Hi
Column 2 are given values. Apologies, my table is a bit messed up. Values within the same row should not be subtracted on the added values. It should be
Column 1Column 2Result(should be computation)
102010same value in Column 1
22010Column 2 - Column 1 row 1 (20-10)
5208Column 2 - Column 1 rows 1 to 2 (20 - 10 +2)
3203Column 2 - Column 1 rows 1 to 3 (20 - 10 +2 +5)
2152
11513
31512
4159
mmarchandTSI
In that case:
If(
	Row() == 2 | Lag( :Column 2, 2 ) != :Column 2, :Column 2 - Lag( :Column 1 ),
	Lag( :Result ) - Lag( :Column 1 )
