UserID16644
How to subset data with some headers in rows?
Hi, I have a big data which has headers inside some rows. I wanted to subset the data per header with its value. My data looks something like this:
Header 1Column 2Column 3Column 4
1111
1111
1111
Header 2Column 2Column 3Column 4
2222
2222
Header 3Column 2Column 3Column 4
3333
3333
3333
I need to subset the data per Header, so I should have Header 2 with
2222
2222
Header 3
3333
3333
3333
I tried creating a Flag column, assign 1 to each header then subset. But the result is incorrect as it subset 1 and blank with Subset 1 with all the headers. This is what I created:
CSV << New Column ("Flag", Numeric);
r = CSV << getRowsWhere( Contains( :Header 1, "Header " ));
Column(CSV, "Flag")[r] = 1;
Please help
Re: How to subset data with some headers in rows?
Move Header1 "down" from the column name (if it is there),
create flag column with formula such as
If(Starts With(:Column 1, "Header"),
	flag = :Column 1
flag;
Then you can subset using that new column as By
10 REPLIES 10
	flag = :Column 1
flag;
UserID16644
Sorry, Im a little bit confused. How did you create Header1 Column?
Using Column Names -> Move down
Level XIII
	flag = :Column 1
flag;
cool , temporary flag - available also for subsequent rows.
You might want to make it a bit more robust by making sure it has been initialized for example by using As Constant() (or If(Row() == 1,....). In this case is wasn't necessary so I didn't bother with it
As Constant(flag = "");
	flag = :Column 1
flag;
Also the readability might improve with something like
If(Starts With(:Header 1, "Header"),
	flag = :Header 1
	flag
You just want to "return" the value you wish to see in rows.
UserID16644
I mean Column 5, sorry for the confusion. Is that from the formula? Im using JMP16 and it has an error
Name Unresolved: flag in access or evaluation of 'flag' , flag/*###*/
After having correct column headers, create new column with a formula
UserID16644
Can this be done using JSL?
Yes. I think JMP can record all these actions and you can get the script from enhanced log (or build workflow)
