How to split a column cells into different columns
Not sure how I can split a column of cells into different columns. For example I have this ONE column with both First and Last names as one cell
Name
1 Lee, Bob
2 Miller, Mike
3 Smith, Jack
Not split this one column into Two columns, one of First, and second column of Last
Last First
1 Lee Bob
2 Miller Mike
3 Smith Jack
12 REPLIES 12
Re: How to split a column cells into different columns
If you're using JMP 12 or later you can use Cols -> Utilities -> Text to Columns.
If you're using JMP 11 or earlier you can get the add-in, Text to Columns, Version 2​, which does the same thing as the now, built-in function.
If you want to do this by hand, either with JSL or the Formula Editor, you'll find the Word() function handy, as described by thechadd
Last Name: Word( 1, :Name, ", " )
First Name: Word( 2, :Name, ", " )
ENTHU
Looking for an extension of Text to Columns/Word function.I have a path in a column -
Z:\abc\def\foldername\filefolder\filename.
I need to extract 3 things from this path -
1.foldername
2.Path until file folder
3.file name
I am basically getting this data from data base.Need to post process it and fill an excel template.
I tried text to columns;going through multiple iterations will get me there but its very inefficient.
Looking for recommendation.
Thanks
Take a look at the Word() function and the Substr() function. And you could also use a regular expression with Regex() function
