Dear Jim,
This kind of plot would do the trick of multiple Y axes
However the scaling problem mentioned by charleslean is not easily overcome!
Is there a script I can use, because 1) uniform scaling does not work since it makes the range too wide and 2) I did not understand how to implement cell color according to nominal modeling.
Here is the cell plot script output from the dialog menu:
Cell Plot(
Scale Uniformly( 1 ), // Ideally there should be a way to set max and min range for the color plot here
Center at zero( 1 ),
Y( :Name( "% of transcript" ) ),
X( :Function Class ),
Label( :Gene Ontology, :Function ),
Legend( 1 ),
Dispatch( {}, "Cell Plot Report", FrameBox, {Frame Size( 616, 106 )} ),
Dispatch( {}, "Cell Plot Report", FrameBox( 3 ), {Frame Size( 616, 106 )} ),
Dispatch( {}, "Cell Plot Report", FrameBox( 5 ), {Frame Size( 616, 106 )} ),
Dispatch( {}, "", NumberColBox, {Set Format( "Fixed Dec", 6, 0 )} )
Your wizardry would be greatly appreciated!
Best, ezra
