imazarrasa
How to set glm for gamma distributed dependent variable
My data is continuous and follow a ganma distribution. Which distribution and link function should I choose in the GLM platform? There is not option for ganma distribution..
I am using JMP 15.0.0
I.
Re: How to set glm for gamma distributed dependent variable
Use the exponential distribution and start with the reciprocal function as the canonical link.
imazarrasa
Thank you very much for the answer.
And, in the case the data are continuous and don't follow a normal distribution nor a ganma distribution (even if they are log transformed), is it possible to apply a glm?
Thanks again for your attention,
Inés.
That question is not simple. The generalized linear model is very flexible with many choices from the family of natural exponential distribution models and link functions. So the choice of the best model depends on many things. The model assumptions and performance should be verified independently of the training of the model.
The GLM is decades old and has enjoyed a lot of attention, so there are many excellent resources created by experts. It is worth investing the time to study some of them if your modeling is important. For example, the on-line SAS documentation for SAS/STAT PROC GLM is a good place to start.
