Adam_Xu
Import csv file using specified row as column names
Hi all,
I wonder to import csv file using specified row as column names (row 3 in this case).
Here is the csv file format:
Here is the target jmp table format I want:
I wrote the below scripts, but failed:
Screen Shot 2020-01-30 at 1.18.11 AM.pngHere is my scripts:
Files = Pick File(
	"Select CSV File",
	"$Downloads",
	{"JMP Files|jmp;jsl;jrn", "All Files|*"},
	1,
	0,
	"multiple"
For( i = 1, i <= N Items( Files ), i++,
	Try( Open(
		Files[i],
			Worksheet Settings(
			1,
				Has Column Headers(1),
				Number of Rows in headers(2),
				Headers Start on Row(2),
				Data Starts on Row(8)
Any advice? Thanks
Re: Import csv file using specified row as column names
Here is the source used by JMP to open a .csv file.  As can be seen, there are options for Column Names Start() and Data Starts().
You should be able to modify this code to meet your needs
Open(
	"C:\Users\Jim\Documents\Big Class.csv",
	columns(
		New Column( "name", Character, "Nominal" ),
		New Column( "age", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "sex", Character, "Nominal" ),
		New Column( "height", Numeric, "Continuous", Format( "Best", 12 ) ),
		New Column( "weight", Numeric, "Continuous", Format( "Best", 12 ) )
	Import Settings(
		End Of Line( CRLF, CR, LF ),
		End Of Field( Comma, CSV( 0 ) ),
		Strip Quotes( 1 ),
		Use Regional Settings( 0 ),
		Scan Whole File( 1 ),
		CompressNumericColumns( 0 ),
		CompressAllowListCheck( 0 ),
		Labels( 1 ),
		Column Names Start( 1 ),
		Data Starts( 2 ),
		Lines To Read( "All" ),
		Year Rule( "20xx" )
Adam_Xu
Sorry, this scripts:
Files = Pick File(
	"Select CSV File",
	"$Downloads",
	1,
	0,
	"multiple"
	Try(
		Open(
			Files[i],
			Worksheet Settings(
				1,
				Has Column Headers( 1 ),
				Number of Rows in headers( 2 ),
				Headers Start on Row( 3 ),
				Data Starts on Row( 4 )
Open(
	columns(
	Import Settings(
		Strip Quotes( 1 ),
		Labels( 1 ),
		Data Starts( 2 ),
		Year Rule( "20xx" )
Adam_Xu
Thank you, Sir! It works
