jconte
How to script an aggregate column from a variable list of column references
I have a list of columns that I need to aggregate automatically. Currently, what I'm trying is something like this, which isn't yielding any results.
cols = {:col1, :col2, :col3}
Eval(Eval Expr(
  dt << New Column(
    Formula(Minimum(Expr(cols))
I've also tried generating this interactively and saving the column formula. It works, but gives me
Minimum(:col1, :col2, :col3)
which I'm not sure how to re-create in JSL.
ErraticAttack
Re: How to script an aggregate column from a variable list of column references
Here are two methods you might try:
Names Default to Here( 1 );
cols = dt << Get Column Names( "String" );
col list = {};
For Each( {col}, cols,
	If( Ends With( col, "t" ), Insert Into( col list, As Name( col ) ) )
Eval( Eval Expr(
dt << New Column( "NEW_COL", "Numeric", <<Set Formula( Min( Eval List( Expr( col list ) ) ) ) )
col list = Expr( Min() );
Eval( Eval Expr(
dt << New Column( "NEW_COL", "Numeric", <<Set Formula( Expr( Name Expr( col list ) ) ) )
Jordan
This might give some ideas Using list of columns in formulas
View more...
cols = {:height, :weight};
// this should work, but formula looks "weird" due to brackets {}
Eval(Eval Expr(
	col1 = dt << New Column("with_brackets", Numeric, Continuous, Formula(Minimum(Expr(cols))))
min_f = Substitute(cols, Expr(List()), Expr(Minimum()));
Eval(Eval Expr(
	col2 = dt << New Column("no_brackets", Numeric, Continuous, Formula(Expr(NameExpr(min_f))))
show(col1 << get formula, col2 << get formula);
Thierry_S
Try this syntax:
Names default to Here (1);
dt = Current Data Table ();
cols = {:col1, :col2, :col3};
dt << New Column("TEST", numerical, continuous, << Formula(Minimum(Eval(cols))));
Best,
TS
Thierry R. Sornasse
jconte
Thanks for the quick response! I tried this, but it seems to leave the column formula unresolved (as Minimum(Eval(cols)) ).
Please check your list definition and make sure the ":" is specified in front of each column name.
What version of JMP are you using?
jconte
My actual list is defined through regex matching based on user input. The script iterates through the data table's list of column names and inserts matching ones into a list.
For Each ({col}, colNames,
  If (condition... Insert Into(list, :Column(col))
I tried changing the syntax to :(Column(col)) but that resulted in a list of missing items rather than what I had previously been getting ({Column(col1), Column(col2), ...}). Same goes for As Column(col).
I'm using JMP 16.
I am guessing on what your initial column names list looks like, but if it is just an unquoted list o column names, the below script is an example of onw way to process it
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
Open( "/C:/Program Files/SAS/JMPPRO/15/Samples/Data/Big Class.jmp" );
colNames = dt << get column names;
theList = {};
For Each( {col}, colNames,
	Show( col );
	If( As Column( col ) << get data type == "Numeric",
		Insert Into( theList, As Column( col ) << get name )
theString = Concat Items( theList, ",:" );
Eval( Parse( "dt << new column(\!"test\!",formula(minimum(:" || thestring || ")));" ) );
ErraticAttack
col list = {};
Eval( Eval Expr(
Eval( Eval Expr(
Jordan
