It sounds as if you are generating your JSL from scratch....like a Python programmer would do, rather than taking the interactive Graph Builder that you produced and then having JMP generate the JSL that will create the graph. If I interactively create the below graph,
By going to the red triangle and selecting "Script" it produces a script that handles both Y axis variables
Graph Builder(
Size( 528, 448 ),
Variables( X( :age ), Y( :height ), Y( :weight, Position( 1 ) ) ),
Elements(
Points( X, Y( 1 ), Y( 2 ), Legend( 5 ) ),
Smoother( X, Y( 1 ), Y( 2 ), Legend( 6 ) )
Dispatch(
"400",
ScaleBox,
{Legend Model(
5,
Base( 0, 0, 0, Item ID( "height", 1 ) ),
Base( 1, 0, 0, Item ID( "weight", 1 ) )
Now, if your issue is, that when you take a script like the one above, and are trying to expand it to handle as many Y columns as you need, that can sometimes require a bit more work.
Here is the same structure of a graph, but with many more Y columns
Here is the expanded JSL that JMP produced to recreate the graph
Graph Builder(
Size( 528, 458 ),
Variables(
X( :Wafer ID in lot ID ),
Y( :NPN1 ),
Y( :PNP1, Position( 1 ) ),
Y( :PNP2, Position( 1 ) ),
Y( :NPN2, Position( 1 ) ),
Y( :PNP3, Position( 1 ) ),
Y( :IVP1, Position( 1 ) ),
Y( :PNP4, Position( 1 ) )
Elements(
Points(
X,
Y( 1 ),
Y( 2 ),
Y( 3 ),
Y( 4 ),
Y( 5 ),
Y( 6 ),
Y( 7 ),
Legend( 3 )
Smoother(
X,
Y( 1 ),
Y( 2 ),
Y( 3 ),
Y( 4 ),
Y( 5 ),
Y( 6 ),
Y( 7 ),
Legend( 4 )
Dispatch(
"400",
ScaleBox,
{Legend Model(
3,
Base( 0, 0, 0, Item ID( "NPN1", 1 ) ),
Base( 1, 0, 0, Item ID( "PNP1", 1 ) ),
Base( 2, 0, 0, Item ID( "PNP2", 1 ) ),
Base( 3, 0, 0, Item ID( "NPN2", 1 ) ),
Base( 4, 0, 0, Item ID( "PNP3", 1 ) ),
Base( 5, 0, 0, Item ID( "IVP1", 1 ) ),
Base( 6, 0, 0, Item ID( "PNP4", 1 ) )
Graph Builder(
Size( 528, 458 ),
Variables(
Y( :NPN1 ),
Elements(
Points(
X,
Y( 1 ),
Y( 2 ),
Y( 3 ),
Y( 4 ),
Y( 5 ),
Y( 6 ),
Y( 7 ),
Legend( 3 )
Smoother(
X,
Y( 1 ),
Y( 2 ),
Y( 3 ),
Y( 4 ),
Y( 5 ),
Y( 6 ),
Y( 7 ),
Legend( 4 )
Dispatch(
"400",
ScaleBox,
{Legend Model(
3,
This is where the JSL programmer has to create the command string to execute to pass to Graph Builder. If you are already doing this, and you are only getting the 1st Y variable in the graph, then typically what is happening is that Graph Builder isn't able to evaluate the information being passed to it. If you provide the JSL you are using, the Community is usually pretty good at helping.
