WHTseng
How to return value from number edit box for many items
Hi JMPers,
Some problems about the return values of number edit box.
I have referred to other posts(combining number box , collect all data in new window), and try to create my code.
Since I have many items to be given value, typing number into every item is not practical for me.
So the "New Window" and "Append" are used to dispose the return value for many items.
Eventually the code just return the default value(1) rather than the number I key in.
Can you help to check which steps are wrong in my code?
Thank you for great help in advanced.
list = {"A", "B", "C","D","E","F","G"};
val={};
nw = New Window( "example",
	v = V List Box(),
	Button Box( "OK", Set Script( nw<<close window) )
For( i = 1, i <= n items(list), i++,
	(v << append(
		Outline Box( "",
			H List Box(
				Text Box( list[i] ),
				exq =number Edit Box( 1 ),
	Insert Into( val, exq<<get);
) ); show(val);
Re: How to return value from number edit box for many items
The issue you are having, is that you are assuming that each separate specification of "exq" is being retained in a unique instance.  What is actually happening, is that they are being written on top of each other.  The code below, separates the instances.
list = {"A", "B", "C", "D", "E", "F", "G"};
val = {};
nw = New Window( "example", v = V List Box(), Button Box( "OK", Set Script( nw << close window ) ) );
For( i = 1, i <= N Items( list ), i++,
	Insert Into( val, 1 );
	(v << append(
		Outline Box( "",
			H List Box(
				Eval(
					Substitute(
							Expr(
								__exq__ = Number Edit Box(
									1,
									10,
									<<SetFunction( Function( {this}, val[__i__] = __exq__ << get ) )
						Expr( __exq__ ), Parse( "exq" || Char( i ) ),
						Expr( __i__ ), i,
val = {};
	(v << append(
		Outline Box( "",
			H List Box(
				Eval(
					Substitute(
							Expr(
									1,
									10,
						Expr( __i__ ), i,
WHTseng
Thank you Jim, that is really a good way and helps me to understand more about "Expr", "substitute, and "Eval".
For << SetFunction ( Function ( {this} , val[i] = exq << get ) ),
I guess I can take the "this" away and leave an empty bracket. (I have tried and it still worked)
Will it be any potential risk to keep the bracket empty?
Thank you.
Here is a modified version of the Example taken from
     Help==>Scripting Index==>TextEditBox==>Set Function
that illustrates the purpose of "{this}"
New Window( "Example",
	xx = Text Edit Box( "pw?" ),
	Text Box( "" )/* here's the sibling box, waiting to show the pw */
xx << SetFunction(
	Function( {this},
		this << passwordStyle( 1 );/* hide my display*/ /* put my password into my sibling's display */
		(this << sib) << settext( this << getText );
WHTseng
Hi Jim,
Really thank you for the professional reply.
I make my code based on all your suggestions, but I find the problems about sequential execution (the JSL executes all the following codes even if I haven't clicked the "OK" yet).
So I have to put all my following code into Set Script to ensure the correct executive sequence.
There are 2 options crossing my mind,
1) Can this method be used in the <<modal? It seems <<modal can stop the JSL running till I click "OK".
2) Does wait(0) work here? and where I should put it among the code?
Here is my simplified code to show my problems, I mark 2 lines as blue to show what I have done,
val = {};
	v = V List Box(),
	Button Box( "OK",
		Set Script(
			nw << close window;
			New Window( "result", <<modal, Text Box( val ) );
	(v << append(
		Outline Box( "",
			H List Box(
				Eval(
					Substitute(
							Expr(
								exq = Number Edit Box(
									1,
									10,
									<<SetFunction(
										Function( {this},
											val[i] = exq << get
						Expr( exq ), Parse( "exq" || Char( i ) ),
						Expr( i ), i,
nw2 = New Window( "fake result", <<modal, Text Box( val ) );
You are correct that JMP will continue processing even without clicking OK.  Unless you do 1 of 2 things.  Make your display window a "Modal" window
nw = New Window("Test Window", Modal, ....................);
Which will force the processing to wait for the window to be cleared.
     Or
Structure your code into Functions() or Expressions, Expr(), which will not execute the code within them, until expressly called from either your window code, or from another Function() or Expr()
