The Discovery Summit 2025 Call for Content is open! Submit an abstract today to present at our premier analytics conference.
Dipesh
Extract string from name
I would like to extract a string of data from a name. The position of the string varies in the name and the name has a variable number of sub-strings within it. An example is shown below:
(GPN) CI-4/E7/DH-1 15S-40 L1807
DEO (GPN) JD CI-4/E7/DH-1 5S-40 L1807
(GPN) JD CI-4/E7/DH-1 40 L1807
I am interested in two parts: a string which contains the letter S (so in the examples, 15S-40 & 5S-40) AND if w is not present, I am interested in the numeric value.
Is it possible to extract this using standard formula functions?
Any help would be great.
Thanks,
Dipesh
pauldeen
Re: Extract string from name
You haven't provided an example of something with a W in it so that is untested. I think this will solve your problems:
YourList = {"(GPN) CI-4/E7/DH-1 15S-40 L1807", "DEO (GPN) JD CI-4/E7/DH-1 5S-40 L1807", "(GPN) JD CI-4/E7/DH-1 40 L1807"};
Part1 = Part2 = {};
For(i=1,i<=N items(YourList),i++,
	SubWords = Words(YourList[i], " ");
	For(k=1,k<=N Items(SubWords),k++,
		If(contains(SubWords[k],"S")>0,
			Part1[i] = SubWords[k];
			k=N Items(SubWords)+1;
For(i=1,i<=N items(Part1),i++,
	If(contains(part1[i],"W")==0,
		Part2[i] = right(part1[i],2);
It appears that the component you want to strip off is the second to the last grouping.  If that is the case, then the code below will do that.  The Word() function is a very powerful function.  It's documentation can be found in either the Scripting Guide or the Scripting Index
     Help==>Books==>Scripting Guide
     Help==>Scripting Index==>Word
dt = New Table( "test",
	New Column( "String",
		character,
		values(
dt << New Column( "Value", character, formula( Word( -2, :String, " " ) ) );
Dipesh
Thanks for the reply.
Unfortunately there is no commonality where the word I would like to extract is in the string - sometimes it is position 2 sometimes it is position 7!
Regards,
Dipesh
thickey1
Using a Regular Expression you can match a 'space' followed by some characters until you hit an 'S-' then more characters until you hit the next 'space'
PAT = "(GPN) CI-4/E7/DH-1 15S-40 L1807";
x = regex(PAT,"\S+(?=S-).* ");
show(x);
pauldeen
Part1 = Part2 = {};
