robot
How to return all matched results from Regex?
How can I return all results from a Regex search?
I am using JMP 18.1.2.
string = "I am looking for ^this^, ^that^, and sometimes ^those^.";
result = Regex( string, "\^([^\n]*?)\^" ); // Only returns first match.
Re: How to return all matched results from Regex?
To my knowledge just using Regex (or Regex Match) are not able to do it at the moment, Add flag to Regex Match() to find all non-overlapping occurances of pattern . You could use Python but you can also use JSL with a loop
result = Regex(string, "\^([^\n]*?)\^"); // Only returns first match.
matches = {};
While(!Is Missing(result = Regex(string, "\^([^\n]*?)\^")),
	Substitute Into(string, result, "");
	Insert Into(matches, result);
show(matches); // matches = {"^this^", "^that^", "^those^"};
or the much more complicated option of JMPs "own" pattern matching Scripting Guide > Types of Data > Pattern Matching
The Regex Match() function might work.
robot
Thanks for the input.  Regex Match() still does not return all results.  At least not the way I have written it.
result = Regex( string, "\^([^\n]*?)\^" ); // Returns "^this^".
Show( result );
results = Regex Match( string, "\^([^\n]*?)\^" ); // Returns {"^this^", "this"}.
Show( results );
matches = {};
robot
Using JMP's Word() function along with Jarmo's methodology one can also solve the problem.
matches = {};
While(!Is Missing(result = word(2,string, "^")),
	Substitute Into(string, "^"||result||"^", "");
matches = {"this", "that", "those"};
