PhamBao
How to rename column of summary table?
Hi all,
I have one summary table and I would like to rename one or two columns of the summary table
My script is like below:
ST_NEW = dt << Summary(
	Group( :prodgroup3, :link_id, :complevel_1, :test_or_bond_head_id, :bondstage ),
	Mean( :align_ratio_2 ) << Name( "align " ),
	Std Dev( :align_ratio_2 ),
	Output Table Name( "ST_NEW" ),
I would like to rename circled columns to new names
Could anyone help me to solve this?
Sincerely,
Re: How to rename column of summary table?
there are 2 issue.
  1. By default, the summary daata table produced is Linked to the original table, which forces the table to be locked.  This defaule needs to be over ruled.
  2. The renaming of the column needs to be done after the new table is produced.
// Open Data Table: big class.jmp
// → Data Table( "big class" )
	Group( :sex ),
	Mean( :height ),
	Std Dev( :height ),
	link to original data table( 0 )
ST_NEW:"Mean(height)"n << set name( "align" );
ih
Super User (Alumni) ih
If being linked to the original table is important (you want to select a row in the summary and have relevant rows in the original table be selected, for example) you could make a new column with the name you are looking for and then hide the original:
Names default to here(1);
	Group( :sex ),
	Mean( :height ),
	Std Dev( :height ),
ST_NEW << New Column("align", Numeric, "Continuous", Format("Best", 12), Formula(:"Mean(height)"n));
ST_NEW:"Mean(height)"n << Hide( 1 );
you can also rename those stat columns with the drop down in below menu ...
