  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
BabyDoragon
How to record the classification of data points within ellipses in a Scatter Plot Matrix after clustering?
The following JSL code can be used to display a ScatterPlot Matrix after Clustering.
Normal Mixtures(
	Y( :height, :weight ),
	{Mixtures Tolerance( 0.00000001 ), Mixtures MaxIter( 300 ),
	Mixtures N Starts( 30 ), Outlier Cluster( 0 ), Diagonal Variance( 0 ),
	Number of Clusters( 2 ), Go( Scatterplot Matrix( Ellipse Alpha( 0.1 ) ) )},
		Dispatch( {"Normal Mixtures NCluster=2"}, "Correlations for Normal Mixtures",
			OutlineBox,
			{Close( 0 )}
		Dispatch( {"Normal Mixtures NCluster=2", "Scatterplot Matrix"}, "101",
			ScaleBox,
			{Min( 59.68 ), Max( 179.498666666667 ), Inc( 20 ), Minor Ticks( 0 )}
I need assistance with the following two questions:
(1) How can I set the Ellipse α to 0.4 in the JSL code?
(2) I would like to record the points included in the Ellipse with an α of 0.4, where the points within the red Ellipse are labeled as 1, those within the green Ellipse are labeled as -1, and the points outside both Ellipses are labeled as 0. This is similar to saving clusters in a Table, but instead, I want to record the points included in the Ellipses. How can I add this functionality to the JSL code?
Re: How to record the classification of data points within ellipses in a Scatter Plot Matrix after clustering?
It seems like normal mixtures platform might be using it's own scatterplot matrix which isn't that easy to access or manipulate. You could save the clusters to your table and then use Scatterplot Matrix to create the plot
Scatterplot Matrix(
	Y(:height, :weight),
	Group(:Cluster),
	Matrix Format("Lower Triangular"),
	Density Ellipses(1),
	Ellipses Coverage(0.4),
	Group By(:Cluster)
but this won't let you get the points. To get this you can use Fit Y by X platform (use cluster as By column).
This is one place where I know you can select the points inside of the ellipses
As I'm not really sure what you are trying to do (are you just trying to select the points or also have some sort of a report) below is script which does a lot of things
nw = New Window("",
	vlb = V List Box(
		nm = dt << Normal Mixtures(
			{Mixtures Tolerance(0.00000001), Mixtures MaxIter(300), Mixtures N Starts(30),
			Outlier Cluster(0), Diagonal Variance(0), Number of Clusters(2), Go()}
cols = Associative Array(dt << Get Column Names("String"));
nm << Save Clusters;
cluster_col = Associative Array(dt << Get Column Names("String"));
cluster_col << Remove(cols);
cluster_col = (cluster_col << get keys)[1];
vlb << Append(
	sm = dt << Scatterplot Matrix(
		Group(:Cluster),
		Shaded Ellipses(1),
		Group By(Eval(cluster_col))
biv = dt << Bivariate(Y(:weight), X(:height), By(:Cluster), Invisible);
biv << Density Ellipse(0.4, {Select Points Inside});
new_col = dt << New Column("Ellipse", Numeric, Nominal, Formula(
	If(Selected() & :Cluster == 1,
		1
	, Selected() & :Cluster == 2,
		-1
		0
dt << run formulas;
new_col << Delete Formula;
dt << clear select;
// Just for visualization purposes
gb = dt << Graph Builder(
	Size(653, 491),
	Show Control Panel(0),
	Variables(
		X(:height),
		Y(:weight),
		Overlay(:Cluster, Overlay Encoding("Style")),
		Color(:Ellipse)
	Elements(Points(X, Y, Legend(3)))
For(i = 1, i <= 2, i++,
	ls = Report(biv[i])[FrameBox(1)] << Find Seg(LineSeg(1));
	xs = ls << Get X Values;
	ys = ls << Get y Values;
	Eval(EvalExpr(
		Report(gb)[FrameBox(1)] << Add Graphics Script(
			Line(Expr(xs), Expr(ys));
//biv << close window;
