Craige's example below is a better solution, but this code might also be useful.
Here is a little script that does the conversion you want
dt = Open(
"<Path to BSP_jmp.TXT>",
columns(
New Column( "YYYY", Numeric, "Continuous", Format( "Best", 12 ) ),
New Column( "MM/DD", Character, "Nominal" ),
New Column( "DAY", Character, "Nominal" ),
New Column( "hh:mm:ss", Numeric, "Continuous", Format( "h:m:s", 11, 0 ), Input Format( "h:m:s", 0 ) )
// Add 2nd line text to Column Name
For( i = 1, i <= N Cols( dt ), i++,
If( Column( dt, i ) << get data type == "Character" & Column( dt, i )[1] != "",
Column( dt, i ) << set name( Column( dt, i ) << get name || Column( dt, i )[1] )
// Delete second name row
dt << delete rows(1);
// Convert columns that are character but should be numeric, to numeric
If( Column( dt, i ) << get data type == "Character" & Is Missing( Num( Column( dt, i )[1] ) ) != 1,
Column( dt, i ) << set data type( Numeric ) << set modeling type( Continuous )
