UserID16644
How to properly use LAG function in Conditional Statements?
I have this formula but it is adding the value on the same row.
If(
	:Column 2 != Lag( :Column 2 ) | Row() == 1, :Column 1,
	Row() == 2 | Lag( :Column 2, 1 ) != :Column 2, :Column 2 - (:Column 1 + Lag( :Column 1, 1 )),
	Lag( :Result ) - :Column 1
What I would want to do is something like this:
Column 1 and Column 2 are given values. If Column 2 value changes, the result should be like the starting value in Column 1.
Column 1Column 2Result(should be computation)
102010same value in Column 1
22010Column 2 - Column 1 row 1 (20-10)
5208Column 2 - Column 1 rows 1 to 2 (20 - 12 +2)
3203Column 2 - Column 1 rows 1 to 3 (20 - 12 +2 +5)
2152
11513
31512
4159
How can I create a table equation like this?
Re: How to properly use LAG function in Conditional Statements?
By vars are arguments which you can use with Col statistical functions Statistical Functions (jmp.com)
dt = New Table("Untitled 4",
	Add Rows(8),
	Compress File When Saved(1),
	New Column("Column 1", Numeric, "Continuous", Format("Best", 12), Set Values([10, 2, 5, 3, 2, 1, 3, 4])),
	New Column("Column 2", Numeric, "Continuous", Format("Best", 12), Set Values([20, 20, 20, 20, 15, 15, 15, 15])),
	New Column("Result", Numeric, "Continuous", Format("Best", 12), Set Values([10, 10, 8, 3, 2, 13, 12, 9]))
dt << New Column("Calc",
	Numeric,
	Continuous,
	Formula(
		If(Row() == Col Min(Row(), :Column 2),
			:Column 1
			:Column 2 - Col Cumulative Sum(:Column 1, :Column 2) + :Column 1
Where is the value 12 coming from to row 3+ calculations?
UserID16644
Sorry, that's 10
5208Column 2 - Column 1 rows 1 to 2 (20 - 10 +2)
3203Column 2 - Column 1 rows 1 to 3 (20 - 10 +2 +5)
2152
11513
31512
4159
You can use col cumulative sum
If(
	:Column 2 - Col Cumulative Sum(:Column 1) + :Column 1
	Add Rows(8),
	Numeric,
	Continuous,
	Formula(
		If(
I guess Column 2 is some sort of grouping which should reset your "counter"? You can use Col Min to detect that change and use that column as byVar if needed
UserID16644
Yes, Column 2 acts like a reset counter. How do you use byVar in this? Haven't heard and used that function before
	Add Rows(8),
	Numeric,
	Continuous,
	Formula(
			:Column 1
mmarchandTSI
@UserID16644, if your :Column2 ever has the same value again, you'll get undesired results.
New Table( "Untitled 155",
	Add Rows( 12 ),
	New Column( "Column 1",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [10, 2, 5, 3, 2, 1, 3, 4, 6, 2, 5, 3] )
	New Column( "Column 2",
		Numeric,
		"Continuous",
		Set Values( [20, 20, 20, 20, 15, 15, 15, 15, 20, 20, 20, 20] )
	New Column( "Result",
		Numeric,
		"Continuous",
		Formula(
			If(
				Row() == 2 | Lag( :Column 2, 2 ) != :Column 2,
					:Column 2 - Lag( :Column 1 ),
				Lag( :Result ) - Lag( :Column 1 )
	New Column( "Result 2",
		Numeric,
		"Continuous",
		Formula(
			If( Row() == Col Min( Row(), :Column 2 ),
				:Column 1,
				(:Column 2 - Col Cumulative Sum( :Column 1, :Column 2 )) + :Column 1
