NishaKumar
How do you get the confidence intervals output for performance measures in the add ins imbalanced misclassification?
I am wondering if you can let me know how can I get the performance measure Confidence Intervals (lower and the upper limit) and the alpha when I do the add ins imbalanced classification analysis to evaluate models (I picked all the models [except for generalized regression] and sampling techniques).
I am able to get the PR Curve AUC, ROC Curve AUC, but I am not able to locate how to get the confidence interval (identify what confidence interval) as well as the upper and lower limits of the confidence interval. I noticed there is an alpha and I can select the alpha but how do I get an output for the upper and lower limit? Some guidance will be helpful.
Thank you,
Nisha
0 REPLIES 0
