FabioSaragoni
How to prevent unlocking data table?
I am really new to JMP.
I created a script to import data from an Access DB through Query Builder.
I used the following to get a locked data table and it worked.
dt << Lock Data Table( 1 )
I need users to open this locked table to review data but I noticed that it is possible to unlock data by clicking on the top-left red triangle (see screenshot attached) and selecting Unlock Data Table.
Is there an easy way to prevent users from unlocking an open data table?
Thanks!
ian_jmp
Level X
Re: How to prevent unlocking data table?
You may be able to use 'SetEditLock()' in the post-processing script that Query Builder allows:
dt << Set Edit Lock( "Modify Cells", "Add Rows", "Delete Columns" );
