TheDude
How to preserve or recreate Combined Prediction Profiler color shading?
If I run the Fit Modelplatform, the "Combined Prediction Profiler" in the resulting Fit Group has pink shadings that indicate the factor's importance. Now I save the Fit Group, either using Save As, or using Save Script>To data table.
If I close, then re-open the files, and either open the saved Fit Group or re-run the saved script, the Prediction Profiler has now lost the shading.
Why? It's very frustrating. How can I get the shading back without having to manually re-run the model fit?
(JMP 16.2.0 on Windows)
ih
Super User (Alumni) ih
Re: How to preserve or recreate Combined Prediction Profiler color shading?
Hello @TheDude,
I cannot seem to replicate this, can you share a screenshot of the combined prediction profiler you refer to?
TheDude
 Sorry, I can't share a screenshot as it contains proprietary data.
I think there is a way to bring back the color shading manually, but at the moment I can't recall how to do it. I will post it here if I find it.
ih
Can you perform the same analysis on one of the same data sets supplied with JMP, available under Help > Sample Data?
