mvanderaa1
How to change all profiler axis settings at once?
I expected all axes in DoE profiler to change when I press crtl before going into the axis settings but this doesn't work. How do I do this?
A gif of what I'm trying to do. I'm pressing ctrl+alt before going to the axis settings. The changes are only applied to my "spotEnergy" factor.
Byron_JMP
Re: How to change all profiler axis settings at once?
Try this:
Change the axis settings on one graph.
Right click on the axis you just changed
    Edit>Copy Axis Settings.
While holding CTRL. (or Command on Mac)
   Edit>Paste Axis Settings.
In my hands, this broadcasts the copied axis settings to all the boxes.  If you happen to have any categorical factors, they get this too, and it kind of messes up the scale.
Byron_JMP
Try this:
