mystylelife19
How to pick data Quantiles in Distribution?
Hello, i'm making the contour plot using the data in Distribution, Quantiles 75% & 25%. My question is how do i put the data Quantiles 75% & 25% in my Minimum Maximum Contour Values? All the data Quantiles is different from another data.
//Put the spec limit on parameter into current data table
dt = Current Data Table();
// Get the all column names from the data table
columnNames = dt << Get Column Names("String");
// Choose the specific column
cl = New Window("Column Selection", <<Modal,
    HListBox(
		  Panel Box("Make a selection",
			VlistBox(
			  allcolumn = RadioBox(columnNames,
			     prmtr=allcolumn<<get
// If cancel or X was clicked, stop the script
If( cl == {Button( -1 )}, Stop() );
//Open Distribution
col = Column(prmtr);
Distribution(
	Stack( 1 ),
	Arrange in Rows( 2 ),
	Continuous Distribution(
		Column(col),
		Horizontal Layout( 1 ),
		Vertical( 0 )
Contour Plot(
	X( :X, :Y ),
	Y(col),
	Show Data Points( 0 ),
	Fill Areas( 1 ),
	Label Contours( 0 ),
	Transform( "Range Normalized" ),
	Specify Contours( Min( -0.627938 ), Max( -0.547845 ), N( 3 ) )
Re: How to pick data Quantiles in Distribution?
You have few different option, you can make a datatable from distribution results and use that to get the values (right click on the table, make into data table and get script from source, edit as neede) or you could use report subscripting to access the table box which has those values
dist = dt << Distribution(
	Stack(1),
	Arrange in Rows(2),
	Continuous Distribution(Column(:height), Horizontal Layout(1), Vertical(0))
tb_ref = Report(dist)[OutlineBox("Quantiles"), Table Box(1)];
// not the most robust option
tb_vals = tb_ref << get;
lower_idx = Contains(tb_vals[1], "25.0%");
upper_idx = Contains(tb_vals[1], "75.0%");
q_lower = tb_vals[3][lower_idx];
q_upper = tb_vals[3][upper_idx];
show(q_lower, q_upper);
Some sources for accessing reports:
	Stack(1),
	Arrange in Rows(2),
mystylelife19
Thankyou mate, it work for me use report subscripting.
