chandankishor66
Data time format while importing excel sheet
Hello JMP users,
I am trying to import an excel sheet which have two different type date-time format. (screenshot attached below)
After importing in JMP format looks like below:
Can you suggest how to fix date-time format while importing excel sheet in to JMP table.
Thanks,
Re: Data time format while importing excel sheet
I would import the column as a character string, and then create a new formula column where the formula uses the distinction between the rows where the column has "/" vs. "-" to use the 2 different Informats, to input the two different date structures.
WebDesignesCrow
