Fabrice_L
How to permanently change the green color and all JMP graphs ?
By default, many graphs in jmp (particularly in the graph builder) use a green color, which, I clearly do not like. I can change the color or each graph, but this is not very practical. I know Preferences -> Styles, Preferences -> Style, Preferences -> Platforms, but I can not find a way to change this color... I have asked this question in the past, with no answer. Really, a software like JMP can do so many things but can not change the preference of the default color used in all graphs ?
Thanks for any help. F.
12 REPLIES 12
Fabrice_L
Re: How to permanently change the green color and all JMP graphs ?
I was looking for a solution to change permanently the color, not for a single graph. The solution has been found (see discussion), but necessitates a JSL script.
Thanks !
nascif_jmp
You can use the Preferences panel to change the Distribution Histogram color.
But that does not affect the color of the Histogram in the Graph Builder.
nascif_jmp
My bad, I tried the JSL fragment and it works for the Graph Builder histogram. It is not the same Preference as the one in Distribution, as I thought it was. Apologies.
