Adi-B
How to perform "find & replace" in specific a column using JSL script?
How can I re-create the "Find & replace" operation on a specific column by JSL script?
For example - I want to replace "K" with "1e3" & "M" with "1e6" in "Count" column
(to convert it to numeric type later).
I didn't find a simple way to do it without using a loop (there so it would be fast when many rows needs to be checked)
Re: How to perform "find & replace" in specific a column using JSL script?
@DonMcCormack
The big win on a lot of the ways you might do this will be to use the Begin/End Data Update as @jthi showed. Here's another way to do it:
dt = Open( "$sample_data/big class.jmp" );
dt << Begin Data Update;
For Each Row( dt,
	dt:name = Substitute( dt:name,
		"A", "a",
		"E", "e",
		"I", "i",
		"O", "o",
		"U", "u"
dt << End Data Update;
Lower case vowels.Lower case vowels.
I think Recode can do this:
Other way would be creating new column with some sort of column:
conversionAa = ["K" => "1e3", "M" => "1e6"];
If(Contains(conversionAa, Right(:Count, 1)),
	Substitute(:Count, Right(:Count,1), conversionAa[Right(:Count, 1)])
My suggestion would be to use Recode and if you need the script you can get it from the Recode platform:
dt = Data Table("Untitled");
col1 = dt << New Column(dt:Count);
col1 << Set Name("Count 2");
dt << Move Selected Columns({col1}, after(dt:Count));
dt << Recode Column(
	dt:Count,
	{Substitute(_rcNow, "K", "1e3"), Substitute(_rcNow, "M", "1e6")},
	Target Column(col1)
@DonMcCormack
For Each Row( dt,
		"A", "a",
		"E", "e",
		"I", "i",
		"O", "o",
		"U", "u"
Adi-B
Thanks a lot !!
Thanks @Craige_Hales. Looks like the makings for a good Challenge question.
