Agustin
How to pass columns as arguments for a function
I'm trying to create a function that creates a new column and sets a formula:
my_function = Function( {name, col1, col2},
	dt << New Column( name, Character);
	Column(dt,name) << Set Formula(
	If(
		:col1 == "Positive" & :col2 ==
		"TRUE",
		"True Positive",
		If(
			:col1 == "Negative" & :col2== "TRUE",
			"False Positive",
			If(
				:col1 == "Negative" & :col2 == "FALSE",
				"True Negative",
				If(
					:col1 == "Positive" & :col2 == "FALSE",
					"False Negative",
But when I look at the formula created it passes on col1 rather than the string behind it.
Calling the function as:
my_function("New Column", Column("column_1"), Column("column_2"));
Re: How to pass columns as arguments for a function
I always pass in columns with names (and table reference). And if you need formula use Insert one expression into another using Eval Insert, Eval Expr, Parse, and Substitute methods to build it (I prefer Eval(EvalExpr()) but in your case I would use Eval(Substitute()). Here is one option how you could handle this
my_function = Function({dt, name, col1, col2},
	new_col = Eval(Substitute(
		Expr(dt << New Column(name, Character, Formula(
			If(_col1_ == "Positive" & _col2_ == "TRUE",
				"True Positive",
				If(_col1_ == "Negative" & _col2_== "TRUE",
					"False Positive",
					If(_col1_ == "Negative" & _col2_ == "FALSE",
						"True Negative",
						If(_col1_== "Positive" & _col2_ == "FALSE",
								"False Negative",
		Expr(_col1_), Name Expr(AsColumn(dt, col1)),
		Expr(_col2_), Name Expr(AsColumn(dt, col2))
	return(new_col)
col = my_function(dt, "test", "name", "sex");
Also JMP does have option to use elseif (even though it isn't written) and it might work in your case instead if nesting multiple if-statements
View more...
				"True Positive",
				"False Positive",
				"True Negative",
				"False Negative"
	return(new_col)
				"True Positive",
					"False Positive",
						"True Negative",
								"False Negative",
	return(new_col)
View more...
				"True Positive",
				"False Positive",
				"True Negative",
				"False Negative"
	return(new_col)
Agustin
Thanks a lot, exactly what I needed. Also the elseif is so much better! Thanks for sharing
Level XIII
If you prefer to use column (aka :age) instead of Strings ("age") to reference the columns, there are 2 problems to be solved:
  1. a manually generated function evaluates it's arguments.
    So if you use a column as a function argument, Jmp will evaluate it  (i.e. return the value of the current row *)
    to prevent it:
    wrap the column with Name Expr()
  2. In most of the cases Jmp doesn't replace variables (like  "col1") with their value (the respective column),
    e.g. in new column() or << set formula
    →  to force Jmp to do so:
    use Eval(Eval Expr( .... Expr(xyz) ...) to evalute xyz before evaluating the remaining part.
    2b) to prevent Jmp from over-evaluating the column reference (like in *), use Name Expr()again,
    so, in combination, use
    Expr(Name Expr(colX))
    ... wherever you want to use the column
in total:
my_function = Function({name, col1, col2},
	new_col = Eval(Eval Expr(New Column(name, Character, Formula(Expr(Name Expr(col1)) /* #2b */  - Expr(Name Expr(col2))/* #2b */ )))); // #2
col = my_function("diff", Name Expr(:height), Name Expr(:weight)); //#1
Here is one way to handle this
dt = New Table( "Example",
	Add Rows( 5 ),
	New Column( "a",
		Character,
		"Nominal",
		Set Values( {"Positive", "Positive", "Negative", "Negative", "unknown"} )
	New Column( "b",
		Character,
		"Nominal",
		Set Values( {"TRUE", "FALSE", "TRUE", "FALSE", ""} )
	dt << New Column( name, Character );
	Eval(
		Eval Expr(
			Column( dt, name ) << Set Formula(
				If(
					as Column( Expr( col1 ) ) == "Positive" & as Column( Expr( col2 ) )
					 == "TRUE", "True Positive",
					as Column( Expr( col1 ) ) == "Negative" & as Column( Expr( col2 ) )
					 == "TRUE", "False Positive",
					 == "FALSE", "True Negative",
					 == "FALSE", "False Negative",
my_function( "new column", "a", "b" );
