lukasz
How to open an image file after clicking on Picture Box?
Hello Everybody,
I am using picture boxes to display 4 images loaded from files. The size of images needs to be reduced for displaying purposes. However, I would like to open an original image file after clicking on the image displayed in the picture box. I would appreciate for hints how to do that.
Best regards.
//initially no images
img1 = empty();
img2 = empty();
img3 = empty();
img4 = empty();
New Window("Images",
		H List Box(
		Panel Box("El 1",  //place for EL images
			EL1 = Picture Box(img1),
		Panel Box("El 2",
			EL2 = Picture Box(img2),
		Panel Box("El 3",
			EL3 = Picture Box(img3),
		Panel Box("El 4",
			EL4 = Picture Box(img4),
//here images will be opened
//img1 = open("D:\image.tif", tif);
//img1 << set size({image_w_new, image_h_new});
//EL1 << set image (img1);
vince_faller
Re: How to open an image file after clicking on Picture Box?
Could use a mousebox.  But understand that the mousebox will make you lose other mouse functionality for that object (context menus, selecting graphs, etc)
Names default to here(1);
img1 = empty();
img2 = empty();
img3 = empty();
img4 = empty();
	H List Box(
		mb = MouseBox(
			<<setTrackEnable( 1 ),
			<<setTrack(
				Function( {this, clickpt},
					this << setCursor( "Finger" ) /* button-up tracking - use the hand */
			<< Set Click Enable(1),
			<<Set Click(
				Function( {this, clickpt, event}, /*Is Alt Key(),Is Control Key(),Is Shift Key() should be captured on "Pressed" */
					{DEFAULT LOCAL},
					If( event == "Released" | event == "Canceled",
						this << setCursor( "Hand" ) /* switch back to hand immediately */
						this << setCursor( "Finger" ) /* change cursor during drawing */
					If( event == "Pressed",
						img = new image("$SAMPLE_DATA\..\images\Pi.gif");
						img << Set Size({50, 50});
						// EL1 << Set image(img);
						// if you're making a bunch of these you could find the picture box
						// instead of having a direct reference to it
						// this currently is dependent on the tree structure
						pb  = (this << Child()) << Child();
						pb << Set image(img);
		Panel Box("El 2",
		Panel Box("El 3",
		Panel Box("El 4",
Vince Faller - Predictum
vince_faller
img1 = empty();
img2 = empty();
img3 = empty();
img4 = empty();
	H List Box(
		mb = MouseBox(
			<<setTrack(
			<<Set Click(
					{DEFAULT LOCAL},
		Panel Box("El 2",
		Panel Box("El 3",
		Panel Box("El 4",
lukasz
Thank you for suggestions and code! With opening of an original image I meant opening the file for example in Paint in order examine details of image in original size. Is there way to do that? Regards
EDIT:
Actually I could create a new window and then open the image again but in original size.
EDIT:
Ok, I managed to open the new window and display the image (using Paint or something another is actually not necessary). I am providing code from vince_faller with very small changes, maybe it will be helpful for somebody. Thank you once again.
img1 = empty();
img2 = empty();
img3 = empty();
img4 = empty();
New Window("Example",
    V List Box(
		H List Box(
		mb = MouseBox(
			<<setTrack(
			<< Set Click(
					{DEFAULT LOCAL},
						New Window("Image",
							img_big = new image("$SAMPLE_DATA\..\images\Pi.gif");
							//img_big << Set Size({50, 50});
							Picture Box(img_big);
							//pb  = (this << Child()) << Child();
							//pb << Set image(img);
		Panel Box("El 2",
		Panel Box("El 3",
		Panel Box("El 4",
