djhanson
How to make JSL get file timestamp?
Anyone know of any code say utilizing the JSL DLL features to get a file's date/timestamp?  For example, get the timestamp for: "C:\mytest.jmp".  thx... dj
3 ACCEPTED SOLUTIONS
carole
Re: How to make JSL get file timestamp?
I don't know if it's a solution for you but I propose the following jsl :
strPathFile = "C:\mytest.jmp";
//Save batch file to get date file : create DateFile.txt containing date
Save Text File(
    "C:\GetDate.bat",
    "for %%x in ("||strPathFile||") do echo datetime=%%~tx >> C:\DateFile.txt";
//Launch batch file
Open("C:\GetDate.bat");
wait(1);//wait to let time running batch file
//Open DateFile.txt containing date file in a jmp data table
Open("C:\DateFile.txt",
        columns( c000001 = Character ),
    Import Settings(
        End Of Line( CRLF, CR, LF ),
        End Of Field( Comma ),
        Strip Quotes( 1 ),
        Use Apostrophe as Quotation Mark( 0 ),
        Scan Whole File( 1 ),
        Treat empty columns as numeric( 0 ),
        Labels( 0 ),
        Column Names Start( 1 ),
        Data Starts( 1 ),
        Lines To Read( All ),
        Year Rule( "10-90" )
vkessler
Check this out:
timestamp = Creation Date( filePath );
TomF
If anyone landed here like I did, looking for the other file timestamp, I was able to get it with a related function:
timestamp = Last Modification Date( filePath );
carole
Save Text File(
    "C:\GetDate.bat",
//Launch batch file
    Import Settings(
        Strip Quotes( 1 ),
        Labels( 0 ),
        Data Starts( 1 ),
djhanson
Excellent!  That seems to do the trick:).  Thanks Carole!!!
vkessler
Check this out:
TomF
