Jay
Jay
How to loop generate graph for all columns
 Hi, Everyone
I trying to get my first loop work, but stuck with one issue.
It simply gets all cloumns, and loop through and plot all columns.  The problem is in
   test ==  ( y_cols[i] ) ;
My intension is test is the individual columns name,  but when i debug, it seems test is a list of all columns, same as the y_cols.
So when i run the script, it plots only the first column, many times.
 y_cols = dt << get column names(string);
Remove From(y_cols,1,2);
nw2 = new window("My first report");
for(i=1, i <=nitems(y_cols), i++,
       gb=expr(Graph Builder(
             Size( 700,250 ),
             Variables(
                    X( :Part id ),
                  Y( eval(test) ),
                    Overlay( :Time )
             Elements(
                    Points( X, Y, Legend( 12 ) ),
                    Line( X, Y, Legend( 14 ), Summary Statistic( "Median" ) )
                    Dispatch(
                          "400",
                          ScaleBox,
                          {Legend Model(
                                 12,
                                 Base( 0, 14, 0 ),
                                 Base( 1, 14, 1 ),
                                 Base( 2, 14, 2 )
       nw2 << append(gb);
Re: How to loop generate graph for all columns
Here is a minor rework of your code to get the script to work.  The first part of the script just creqates a simple example data table.
Names Default to Here( 1 );
dt = New Table( "Test of Bivariate",
	Add Rows( 30 ),
	New Column(
		["en" => "NPN1", "ja" => "NPN1", "x-id" => "S_NPN1_Col", "zh-CN" => "NPN1"],
		Numeric,
		"Continuous",
		Format( "Best", 10 ),
		Set Property(
			"Spec Limits",
			{LSL( 104.412948990151 ), USL( 131.893493064355 ),
			Target( 118.153221027253 ), Show Limits( 1 )}
		Set Values(
			[114.555760105678, 120.043693059459, 114.926510466106, 111.756445551183,
			111.545085144313, 113.52359591958, 111.749308571209, 114.411433304976,
			118.48975048042, 113.171122695149, 114.946183872216, 113.382890501824,
			114.666518192776, 107.884015560041, 113.065582322339, 116.25374611217,
			118.333680853156, 110.657545008855, 118.693111738676, 115.463396293845,
			110.287898508744, 113.287278281031, 115.219123741957, 112.385219593504,
			120.861530393886, 119.847995090729, 118.65519608864, 112.661846058518,
			114.066130117341, 114.063409994947]
	New Column(
		["en" => "PNP1", "ja" => "PNP1", "x-id" => "S_PNP1_Col", "zh-CN" => "PNP1"],
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
			[322.616751775796, 333.128079728678, 348.978757216574, 268.548094462492,
			295.073165929223, 323.833298568833, 369.320490694357, 342.987400315929,
			315.52243608245, 288.978183718528, 301.607366273833, 283.191076438161,
			212.800492311906, 341.443055295059, 331.555064642669, 278.646245766939,
			354.677433317207, 275.259301200618, 269.055788537937, 244.936754173054,
			469.298298488357, 380.107493803667, 307.351300272484, 395.390913757803,
			248.385309740161, 332.715779503856, 229.971512201935, 282.355854909556,
			278.876672135109, 369.802517417371]
	New Column(
		["en" => "PNP2", "ja" => "PNP2", "x-id" => "S_PNP2_Col", "zh-CN" => "PNP2"],
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
			[469.390289765043, 437.781112798903, 532.12814730405, 373.058628529111,
			338.900737368942, 469.992171436316, 563.084459366587, 479.378108668814,
			530.265608347575, 421.454501563007, 437.625180215708, 391.16014485917,
			336.315923666781, 459.675297352564, 556.117457880758, 393.524854048041,
			524.412197327866, 435.589457872556, 401.432160774864, 414.478191120167,
			549.457336783227, 481.694954348379, 415.372316833295, 590.034261426748,
			455.115879097893, 449.972226523986, 380.251466107595, 377.489216424948,
			429.808729569278, 482.221726694182]
	New Column(
		["en" => "NPN2", "ja" => "NPN2", "x-id" => "S_NPN2_Col", "zh-CN" => "NPN2"],
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
			[115.958473043434, 120.974137316372, 117.75312418797, 114.092607737274,
			113.778098130642, 116.488049497674, 115.935283026742, 115.762801088796,
			116.347793739608, 116.232907922575, 115.336672965867, 117.255145685653,
			118.901572658105, 110.399346473016, 117.429077171413, 117.119143668499,
			114.817571362932, 113.846330724714, 117.688752124707, 117.538298327714,
			112.904566955574, 116.425994464592, 115.927646041683, 114.612962021825,
			116.192793106131, 119.61138824619, 115.311215206548, 115.865219100186,
			115.64507142399, 114.59887334177]
	New Column(
		["en" => "PNP3", "ja" => "PNP3", "x-id" => "S_PNP3_Col", "zh-CN" => "PNP3"],
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
			[130.378809500886, 132.736937590235, 136.831952164704, 136.969154239163,
			136.622623419893, 137.480356512481, 138.094011176166, 142.10586919757,
			134.750041237898, 129.719685093372, 136.520172900026, 134.778624216716,
			136.991131754497, 140.420940666186, 143.257827228986, 132.213765487819,
			144.671172276421, 134.703176752174, 136.744212473486, 137.187637284245,
			139.788226018039, 139.372617199359, 136.112484488985, 142.809097034809,
			137.799370430979, 138.482493403385, 135.236982575217, 136.251777781494,
			130.768356509183, 138.248554728086]
	New Column(
		["en" => "IVP1", "ja" => "IVP1", "x-id" => "S_IVP1_Col", "zh-CN" => "IVP1"],
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
			[73.4842940932646, 75.6074915248983, 73.3304733114595, 75.7647427124531,
			70.5460961797334, 72.9451281758323, 75.6756511920958, 76.4874855218512,
			66.4572544989587, 72.2503891181424, 68.1130267608097, 78.8045562686784,
			76.4765647747647, 74.689323480678, 76.1706490573276, 75.7935715354233,
			72.2088629673599, 65.6494060910306, 75.7923931517876, 77.9990166080606,
			76.6172682677768, 73.7633567469775, 78.5651088817796, 69.8240361090062,
			72.0636364201829, 70.7582455389162, 69.7835283880779, 72.4529462963473,
			69.7646762627277, 75.321634759487]
	New Column( "Date",
		Numeric,
		"Ordinal",
		Format( "ddMonyyyy", 12 ),
		Input Format( "ddMonyyyy" ),
		Set Selected,
		Set Values(
			[3567542400, 3567628800, 3567715200, 3566678400, 3567542400, 3567888000,
			3566764800, 3568665600, 3568665600, 3566937600, 3566678400, 3566419200,
			3566332800, 3568060800, 3566246400, 3567715200, 3567196800, 3566505600,
			3566764800, 3568233600, 3566851200, 3566505600, 3566764800, 3568665600,
			3567456000, 3566246400, 3567801600, 3568492800, 3566419200, 3566160000]
	New Column( "Part ID",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values(
			[1, 2, 3, 4, 1, 2, 3, 4, 1, 2, 3, 4, 1, 2, 3, 4, 1, 2, 3, 4, 1, 2, 3, 4,
			1, 2, 3, 4, 1, 2]
y_cols = dt << get column names( string );
y_cols = Remove( y_cols, 7, 2 );
nw2 = New Window( "My first report" );
For( i = 1, i <= N Items( y_cols ), i++,
	test = y_cols[i];
	gb = //Expr(
	Graph Builder(
		Size( 700, 250 ),
		Variables( X( :Part id ), Y( as column( test ) ), Overlay( :Date ) ),
		Elements( Points( X, Y, Legend( 12 ) ), Line( X, Y, Legend( 14 ), Summary Statistic( "Median" ) ) ),
			Dispatch(
				"400",
				ScaleBox,
				{Legend Model( 12, Base( 0, 14, 0 ), Base( 1, 14, 1 ), Base( 2, 14, 2 ) )}
	nw2 << append( report(gb) );
	gb << close window;
	Add Rows( 30 ),
	New Column(
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column(
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column(
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column(
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column(
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column(
		Numeric,
		"Continuous",
		Set Property(
			"Spec Limits",
		Set Values(
	New Column( "Date",
		Numeric,
		"Ordinal",
		Set Selected,
		Set Values(
		Numeric,
		"Continuous",
		Set Values(
			1, 2, 3, 4, 1, 2]
	test = y_cols[i];
	gb = //Expr(
	Graph Builder(
		Size( 700, 250 ),
			Dispatch(
				"400",
				ScaleBox,
	gb << close window;
Jay
Jay
Thank you. Jim.  That worked.
