Fruit325
How to label the data points in scatter plot on Graph Builder?
Hi, I am creating map using X, Y and Z based on the contour plot. I drag Z to the color option to give different colors.
How could I lable each data point with its Z value? For heat map, I notice there is an option "label on heatmap" but it seems to be not available on contour plot. Thank you!
Re: How to label the data points in scatter plot on Graph Builder?
Depending on your plot, you might want to use Contour instead of Graph Builder
Or if you have JMP18 it should be fairly easy to use labels for your markers (set your Z column as Label column and label all rows in your table)
Fruit325
Hi @jthi
Thanks a lot. In coutour, I use "label the contour" and finally the map is labeled by the Z color gredient. The raw data points are not labeled. Could you please show me how you label the raw data points in Contour? Thank you!
You might be able to do what you want using Label column and by labeling all rows (don't enable Label Contours)
