BookmarkSubscribeRSS Feed
rainwang
Community Trekker
Apr 21, 2016
How to get the bivariate regression results without plot the chart
I have one data table with column X and Y, fit Y by X.
I only what to get the fit results like the coefficent and the intercept without drawing a chart.
who knows how to do it?
Jun 22, 2012
Re: How to get the bivariate regression results without plot the chart
Use the Fit Model platform, rather than the Fit Y by X, and using the options under the Red Triangle, you will be able to unselect all of the unwanted components, including the plot
rainwang
Community Trekker
Apr 21, 2016
Hi, Jim
Thank you! it is helpful!
bill_worley
Jul 2, 2014
Another option to separate the parameter estimates from the report is to right click anywhere in the Parameter Estimates and select "Make into Data Table"
XanGregg
Jun 23, 2011
Another option is to launch the analysis in "invisible" mode and then query the report for the values you want to extract using display box subscripting:
biv = Bivariate( Y( :weight ), X( :height ), Fit Polynomial(2), Invisible);
rep = Report(biv);
//all = rep["Parameter Estimates"][TableBox(1)] <<Get As Matrix;
pe = rep["Parameter Estimates"][Number Col Box("Estimate")] <<Get As Matrix;
biv << Close();
show(pe);
rainwang
Community Trekker
Apr 21, 2016
It's cool. It is what I want, thank you so much!
