- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
How to get "Effect size" column with Response Screening functionality
Hello everyone,
I am using the response screening feature of jmp and I was wondering how the columns are calculated, especially the Effect Size column.
My database contains discrete and continuous variables.
I want to perform a first analysis by selecting only the categorical variables as explanatory variables
And a second analysis by selecting only the continuous variables as explanatory variables.
My response variable is continuous.
However, I wonder how this "Effect Size" column is calculated and if the calculation method is the same or not depending on the nature of the explanatory variables.
Thank you very much
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: How to get "Effect size" column with Response Screening functionality
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Thank you very much!
