miguello
How to get names of the selected columns in string format
In my script I use the following to get the list of all columns in a string format:
columnNames = dt << Get Column Names( string );
I need that so I could iterate through them using "For Each" loop:
For Each( {columnName, index}, columnNames, Column( dt, columnName ) << Set Name( columnName ||"SomethingHere" ) );
Now I need to only get selected columns and run the same loop on them.
I know only one way to get selected columns:
columnNames = dt << Get Selected Columns;
but it returns references to columns, not string names. So when I run this then:
it doesn't work.
How do I either
1. Rewrite For Each loop (I'd like to keep using this loop instead of For loop) to accept references to columns as well
or
2. Convert references to columns into a list of strings.
Re: How to get names of the selected columns in string format
Add (String) to Get Selected Columns (not documented in scripting index... but help has "a bit more" documentation dt<<Get Selected Properties(<{list of properties}>) )
dt << Select Columns({:sex, :height});
sel_colnames = dt << Get Selected Columns(string);
show(sel_colnames); // sel_colnames = {"sex", "height"};
miguello
Ok, I solved it the following way.
Before running my already scripted "For Each" loop that I doin't want to change, I run this:
For Each( {columnName, index}, columnNames, columnNames[index] = columnNames[index]<< Get Name );
Any other options?
miguello
Awesome! **bleep** under-documentation :)
Would be good to report. I just don't remember who was supposed to be tagged when Scripting Index was lacking so for now lets tag @Jeff_Perkinson and@Ryan_Gilmore , << Get Selected Columns is missing optional option parameters in Scripting Index.
Duane_Hayes
Staff (Retired)
@miguello, @jthi  - JMP Technical Support will make the request to update the Scripting Index. Thank you for sharing!
Duane Hayes
