cslim
How to get axis labels to the left of x-axis
I made a scatter plot with three variables on the x axis as shown below, but the label for the the axes (xC/ xB / xA) are at the bottom which can be unintuitive.
I was looking a way to get the labels for the x axis to the left of each x-axis i.e xA on the left of "A1 A2 A1 A2...", xB on the left of "B1 B2...." and so on, so that it forms sort of a hierarchical table.
(I am new to jump, so not sure abut the correct terms for everything.)
Thanks in advance
Re: How to get axis labels to the left of x-axis
Is this what you are trying to do?
If so, in Graph Builder, you just drag the Age column to the X axis, then go back and drag the Sex column to the right end of the X axis
cslim
Thank you for the reply.
 I already have the graph plotted correctly, I want to change only the formatting of the x-axis labels as I have shown in red text here:
I was able to accomplish this interactively and then I had JMP save the JSL to a script window, which gave me the JSL that can be used to produce the graph.  As can be seen in the below graph, I only have 2 levels on my X axis, not 3 as in your example, however the method I used can be easily extended for the 3 levels.
  2. To remove the axis label, I clicked on the    age / sex    to edit it, and used the Backspace key to delete it. txnelson_2-1656655926967.png
  3. Next I used the Annotate Tool  txnelson_4-1656656026619.png to add the Sex label
  4. After it is entered the mouse can be used to position it exactly where it is wanted.
    I then repeated the same step to add the Age label..  The first graph displayed is what the final results were.
  6. The last step was to go to the red triangle and select     Save Script=>To Script Window
    Graph Builder(
    	Size( 525, 458 ),
    	Variables( X( :age ), X( :sex, Position( 1 ) ), Y( :height ) ),
    	Elements( Points( X( 1 ), X( 2 ), Y, Legend( 3 ) ) ),
    		Dispatch( {}, "X title", TextEditBox, {Set Text( "" )} ),
    		Dispatch(
    			AxisBox,
    			{Add Axis Label( "Sex" ),
    			{Add Text Annotation(
    				Text( "Sex" ),
    				Fixed Size( 0 ),
    				Text Box( {-16, 2, 21, 29} ),
    				Filled( 0 )
    			), Add Text Annotation(
    				Text( "Age" ),
    				Fixed Size( 0 ),
    				Text Box( {-15, 26, 26, 53} ),
    				Filled( 0 )
    		Dispatch( {}, "Sex", TextEditBox, {Set Text( "" )} )
     By repeating the Annotate step for your 3rd X axis level, and then saving the script should give you the JSL you need for your graph.
