Agustin
Easy way of reordering columns
I have a script that reformats many files and performs some analysis producing a final summary table, however the order in which the calculations are done and new columns are added doesn't produce a very readable format.
I would like to pass the list of column names in the order I want them.
Is there a built - in way of doing this?
e.g. if I had a table with: Column 1, Column 2, Column 3, Column 4
I want to pass in the list {Column 2, Column 4, Column 1, Column 3} to the table and have the reorder the table columns to match.
Thanks!
Re: Easy way of reordering columns
Here is the way I handle this.  By working backwards through the list, and moving each to the first position, the columns end up as you want them.
myList = {"age", "weight", "height"};
For( i = N Items( myList ), i >= 1, i--,
	Eval( Parse( "dt << Move Selected Columns(" || myList[i] || ", To first )" ) )
stan_koprowski
Nice,  simple and clever solution @txnelson
Agustin
That's such an ingenious fix!
