@jthi Thanks, I have a now used a smaller data set for the analysis (JSL below). I think there is no need to filter outliers on a Wafer ID in a lot ID basis as the outlier cells are rendered missing any way. What I need is a capability analysis on an outlier filtered data set.
Clear Log();
dt_full = Open( "$SAMPLE_DATA/Semiconductor Capability.jmp" );
dt = Data Table( "Semiconductor Capability" ) << Subset(
All rows,
columns( :lot_id, :wafer, :Wafer ID in lot ID, :SITE, :NPN1, :PNP2, :PNP3, :FNM1, :RES3, RSP2 )
Wait( 1 );
Close( dt_full, no save );
col_names = dt << Get Column Group( "Processes" ); // Column Group should pre-exist.
obj = Explore Outliers( Y( Eval( col_names ) ) );//,By( :Wafer ID in lot ID)); // Run expolore outliers
obj << Quantile Range Outliers( Tail Quantile( 0.25 ), Q( 1.5 ) ); // select Q3/Q1 +/- 1.5 x IQR
obj << Color Cells( ALL ); //check
Wait( 1 );
obj << Change to Missing( ALL );
Wait( 1 );
obj << Close Window;
// Run capability analysis
platform = dt << Process Capability(
Process Variables( Eval( col_names ) ),
Spec Limits Dialog( "No (skip columns with no spec limits)" ),
Moving Range Method( Average of Moving Ranges ),
//Within Sigma Summary Report( 0),
Overall Sigma Summary Report( 1 ),
Select Out of Spec Values( 1 ),
Goal Plot( 0 ),
Capability Index Plot( 0 ),
Capability Box Plots( 0 ),
Process Performance Plot( 0 ),
Order By( "Overall Sigma Ppk Ascending" )
Wait( 0 );
Report( platform )[Outline Box( "Process Capability" )][Outline Box( "Overall Sigma Capability Summary Report" )][Table Box( 1 )] <<
Make Into Data Table;
dt_curr = Current Data Table();
dt_curr << Set Name( "Capability Report" );
platform << close window;
dt << Clear Select;
// Run capability analysis by wafer in a lot
platform2 = dt << Process Capability(
Overall Sigma Summary Report(1),
Goal Plot( 0 ),
Order By( "Overall Sigma Ppk Ascending" ),
By( :Wafer ID in lot ID )
dt << Clear Select;
There I want to compare Ppk per parameter for the full data set vs capability of the same parameter on a Wafer ID in a lot ID basis. To this end, I have put together the script below by am struggling to make a combined data table (can do it interactively) from the second capability analysis.
Report( platform2)[Outline Box( "Process Capability" )][Outline Box( "Overall Sigma Capability Summary Report" )][Table Box( 1 )] <<
Make Combined Data Table;
platform2 << close window;
Finally, what I want is a plot of Capability (y-axis) vs Wafer ID in a lot ID (x-axis) generated from the combined data table with Parameter names in Page (on Graph Builder). Also, I need the Ppk calculated form the first capability analysis to be shown as a horizontal line for each parameter. Could I please get some help here?
