mvanderaa1
How to find the reference to an object in a platform using the tree structure?
Hi, I've been trying to use references to objects in analysis platforms (graphs, tables, etc) in scripts, but in my opinion it's not very intuitive from the examples I've seen.
I have multiple use cases, but I'm hoping to find a generic description or manual on how to find the reference to any object in an analysis platform. I'm guessing it exists somewhere on this site but I have not been able to find it.
Re: How to find the reference to an object in a platform using the tree structure?
In my opinion there is no generic solution for this as there are so many different platforms in JMP and some of them do behave differently than others. My general approach is to take a look at the XML with << Get XML and then use XPath (XPath is also nice as it works outside of JSL) with some combination of << sib, << child, <<parent.... If it is a very simple case then I might use report subscripting Scripting Guide > Display Trees > Navigate JMP Reports > Display Box Object References .
Below are some links:
  • Navigating your reports using XPath
  • , Technique 2  starting at 20:30
  • JMP17 is also supposed to have "Automatically create Display Box paths for report scraping via JSL" haven't used this as I have no access to JMP17. Also no idea how generic paths this will create.
9 REPLIES 9
mvanderaa1
Thanks, this is pretty much what I was looking for. I remember the "Steal this code" presentation but I also couldn't find it anymore.
I will accept this as a solution, although I still feel this subject deserves a more concise explanation on JMP learning and/or the scripting Index within JMP so that users know where to start.
mvanderaa1
Looking at the XPath examples I realized many of my problems arise when I use a "group by" variable in the platform.
Taking the example I find in the XPath link:
This script works fine
// not grouped by sex
dt = Open(   "$SAMPLE_DATA\Big Class.jmp" );
ow = dt << Oneway(
	Y( :height ),
	X( :age ),
	Means and Std Dev( 1 ),
	Mean Error Bars( 1 ),
	Std Dev Lines( 1 ),
	Mean of Means( 1 )
testXML = Report (ow) << Get XML;
Write( testXML );
/* Return a list of NumberColBox references */
ncbList = Report( ow )["Means and Std Deviations"] << XPath( "//NumberColBox" );
If I group by sex however, get XML already throws an error. How to handle this?
// group by sex
ow = dt << Oneway(
	Y( :height ),
	X( :age ),
	By( :sex ),
	Std Dev Lines( 1 ),
	Mean of Means( 1 )
// get XML fails for this platform
Write( testXML );
ncbList = Report( ow )[???]["Means and Std Deviations"] << XPath( "//NumberColBox" );
Jeff_Perkinson
When you use a By() you get the message returns a list of platforms, not a single platform.
ow = dt << Oneway(
	Y( :height ),
	X( :age ),
	Std Dev Lines( 1 ),
	Mean of Means( 1 )
Show( ow );
ow_by = dt << Oneway(
	Y( :height ),
	X( :age ),
	By( :sex ),
	Std Dev Lines( 1 ),
	Mean of Means( 1 )
Show( ow_by );
Log:
ow = Oneway[];
ow_by = {Oneway[], Oneway[]};
-Jeff
You could try wrapping Oneway with New Window
// group by sex
dt = Open("$SAMPLE_DATA\Big Class.jmp");
nw = New Window("", ow = dt << Oneway(Y(:height), X(:age), By(:sex), Means and Std Dev(1), Mean Error Bars(1), Std Dev Lines(1), Mean of Means(1)));
testXML = nw << Get XML;
Write(testXML);
ncbList = nw << XPath("\[//OutlineBox[text()="Means and Std Deviations"]//NumberColBox]\");
Level XIII
As Jarmo indicated in his first reply, in JMP17 it got a bit easier now to get the correct XPath for an object:
Right click on the object, click on Show Properties (... adjust the selection if needed) and click on hogi_1-1667501045793.png in the Box Path menu on the right:
Level XIII
another Trick:
Generate the XML code for the current report (not just the report of the object; think about data filters etc.)
I linked the code below to a Keyboard shortcut - and now I can get the XML code for any report that I want.
Just select the report and press (e.g.) CTRL - Alt + X :)
Local({myTitle= Current Report()<< get Window Title() || " - (xml)"},
New Window (myTitle ,<<Type( "Script" ),Current Report()<< Get XML))
There is also a utility function to help with determining the best path to a display box.
Level XIII
really?
I would have guessed that you get your special, personal, free JMP Pro signature editon the first day a new version comes out
... to support you as much as possible in supporting others :)
